OLED 0.91 Inch 128×32 I2C Display Module
5,97
6 varastossa (voidaan jälkitoimittaa)
Osasto:
Note:
  • Do not reverse VCC and GND. This will cause damage to the OLED display.
Pin Description:
  • GND: Power Ground
  • VCC: Power + (DC 3.3 ~5v)
  • SCL: Clock Line
  • SDA: Data Line
Specification:
  • Model: SH-S091
  • Screen size: 0.91 inch
  • Interface: I2C
  • The main chip is: SSD1306;
  • Operating voltage: 3.3V~5.0V power supply.
  • Working Temperature: -30 degrees ~ 70 degrees
  • Display area: 22.384 x 5.584 (mm)
  • Physical size: 38 x 12 (mm)
  • Pixel size: 0.159 x 0.159 (mm)
  • Pixel pitch: 0.175 x 0.175 (mm)
  • Interface Type: IIC Interface
  • Number of Pins: 4Pin
