8 Channel Logic Level Converter Bi-Directional High Speed Full Duplex Shifter 3.3V 5V
1,83
Available on back-order
Category:
Features:
  • Module uses the chip: TXS0108E
  • 8-way high-speed full-duplex level conversion module
  • Provide two-way communication capability
  • VCCA terminal voltage of 1.2V-3.6V support
  • VCCB side support voltage 1.65v-5.5v
  • You can provide other common 3.3-5V 1.8-3.3v level conversion capability
  • The main application, 5V and 3.3V microcontroller module with 5V 3.3V microcontroller module, compatible with other communications support
  • MCU and SD card communication level conversion
  • SCM and iic, spi serial device level converter
  • OE active high enable IO recommended by a low voltage side of the IO port
Reviews
There are no reviews yet.
