- Embed version of Mega 2560 CH340G/ATmega2560 – compatible with Arduino Mega 2560 board
- Built on the Atmel ATmega2560 microcontroller and USB-UART interface chip CH340G.
- Board have compact size 38x55mm. It is good solution, to make your final project on solder proto-board.
- The board used the chip CH340G as converter UART-USB.
- Flash Memory:256 KB of which 8 KB used by bootloader;SRAM:8 KB;EEPROM:4 KB;Clock Speed:16 MHz
MEGA 2560 PRO Micro USB – CH340G/ATMEGA2560-16AU
18,13 €
1 in stock (can be backordered)
Reviews
There are no reviews yet.
